In one of my applications I use a dialog box with a search field. A NotesTimer checks if the value of this field has changed, and if so, refreshes a list of expertises. Since 6.5.2 the Alarm event isn’t fired. I’ve checked this with version 6.5.2, 6.5.3 and 6.5.4. Can someone tell me what I’m doing wrong?
Here’s the code
[The command that launches the dialog box]
@DialogBox ( "(DialogExpertiseSoftware)" ; [AutoHorzFit] : [AutoVertFit] : [NoNewFields] : [SizeToTable] ; "Expertises Software..." );
@Command ( [ViewRefreshFields] )
[Globals \ Declarations]
Dim refreshTimer As NotesTimer
Dim uidoc As NotesUIDocument
Dim oldQuery As String
[Globals \ refreshTimerHandler]
Sub refreshTimerHandler ( Source As NotesTimer )
Dim newQuery As String
Source.enabled = False
newQuery = uidoc.FieldGetText ( "Search" )
If Not oldQuery = newQuery Then
'Perform search and refresh UIDocument...
Source.Enabled = True
[(DialogExpertiseSoftware) \ PostOpen]
Sub Postopen(Source As Notesuidocument)
oldQuery = ""
Set uidoc = Source
Set refreshTimer = New NotesTimer ( 1 , "Refresh search results..." )
On Event Alarm From refreshTimer Call refreshTimerHandler
