notesRichTextItem.EmbedObject help
I am trying to attach a pdf file to a document via lotusscript.
I am uploading the file using the following:
Dim rt As notesrichtextitem
Dim embedOb As NotesEmbeddedObject
'myDoc is currentDocument, Attachment is rich text field
Set rt = myDoc .GetFirstItem( “Attachment” )
'myText is the pdf to uplaod
Set embedOb = rt.EmbedObject (EMBED_ATTACHMENT, “”, “c:\data\mytext.pdf”)
The problem is it does not attach the file itself, but instead adds the contents of the pdf file. It displays just a load of jumbled data. Does anyone know how to just attach a pdf to a rich text field, rather than the contents of it?
PS The same thing happens if I use EMBED_OBJECT.
Subject: notesRichTextItem.EmbedObject help
Did you try this instead?
embedOb = rt.EmbedObject (1454, “”, “c:\data\mytext.pdf”)
Subject: RE: notesRichTextItem.EmbedObject help
Have tried that and get the same problem. This is what it puts in the rich text field:
%PDF-1.2
%âãÏÓ
4 0 obj
/Linearized 1
/O 6
/H [ 734 170 ]
/L 95280
/E 93687
/N 1
/T 95083
endobj
                                                         xref
4 16
0000000016 00000 n
0000000664 00000 n
0000000904 00000 n
0000001055 00000 n
0000001248 00000 n
etc etc
Has anyone else experienced this with attachments? The files open ok. They aren’t corrupt. Just wont attach/embed.
Did you try embedding another file type such as an excel file or text file with the same code? Same behavior?
Yes, tried it with a text file, and entered the file contents rather that the file itself.
Is this the behaviour of when an item is embedded rather than attached? The same happens when i try either option.
Hi i understand ur requirment.
Below i gave sample code.i tested and its working.please match this with ur requirement.
Dim doc As NotesDocument
Dim rtitem As NotesRichTextItem
Dim object As NotesEmbeddedObject
Dim handle As Variant
Set doc = New NotesDocument( session.CurrentDatabase )
Set rtitem = New NotesRichTextItem( doc, "Body" )
Set object = rtitem.EmbedObject _
( EMBED_ATTACHMENT, "", "d:\test.pdf")
doc.Form = "test"
Call doc.Save( True, True )
Set handle = object.Activate( False )
If ( handle Is Nothing ) Then
	doc.Subject = "This object has no OLE automation interface"
Else
	doc.Subject = "This object has an OLE automation interface"
Looking forward for ur reply.
Thanks & regards
Karthik.C
Karthik
I am using your code for my web application but I am getting this error:
Error: Notes error: You are not authorized to perform that operation
Do you have any ideas?
thanks
