NotesMIMEEntity.Remove - Issue with large multi-part mime entities. Not all mime is removed
According to the Designer Help DB,
Remove method
Removes the current MIME entity and its children.
The example code page includes the statement, “This agent removes the MIME entity or all MIME entities (in the case of a multipart MIME entity) from the current document.”
So I feel pretty confident that when I run the following code, all the stored mime information for the concerned NotesItem should disappear.
Sub Initialize()
Dim s As New NotesSession
Dim db As NotesDatabase
Dim dc As NotesDocumentCollection
Dim doc As NotesDocument
Dim item As NotesItem
Dim mime As NotesMIMEEntity
Set db = s.CurrentDatabase
s.ConvertMIME = False
Set dc = db.UnprocessedDocuments
Set doc = dc.GetFirstDocument
If Not(doc Is Nothing) Then
	Set item = doc.Getfirstitem("Body")
	Set mime = item.GetMIMEEntity
	If Not(mime Is Nothing) Then
		Call mime.Remove
	Call doc.Save(True, True)
s.ConvertMIME = True
Well, this works fine, until the NotesItem contains a lot of information. At this point, not all the information is removed. In our situation, as the document has it’s NotesItem recreated and removed multiple times, the document grows quite large with remnant $FILE leftovers that I assume are MIME data not removed.
Doing this in the 8.5.1 client and on Domino 8.5 …
Initial save
After mime removal
After a few more cycles of testing, with the same content in the field as was there after the initial save
If I start with a smaller amount of data stored as HTML/MIME, it is removed completely
Any thoughts out there on how to best remove ALL the mime data related to a Rich Text Field - especially when multiple RTF’s will be involved?
Thanks.
