NotesDOMParser.Process method and "Unable to recognize or load XML reformatter input character set" error
I receive this error:“Unable to recognize or load XML reformatter input character set”
when using the NotesDOMParser.Process method.
Here is the code snippet:
Set oHTTP = CreateObject(“Microsoft.XMLHTTP”)
oHTTP.open "GET", urlToUse, False, "", ""
oHTTP.setRequestHeader "Content-type", "application/x-www-form-urlencoded"
oHTTP.send("")
returnText = oHTTP.responseText
Set oHTTP = Nothing
Set xmlstream = s.CreateStream
xmlstream.WriteText(returnText)
Set parser = s.CreateDOMParser(xmlstream)
Call parser.Process
It errors at the Call parser.Process line.
I found a this post:
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/5b2dca1fba24f9268525704d0013d694?OpenDocument
My XML doc/return text contains whitespace in some of the nodes - could this be causing the problem?
Do I have to format the XML text before I parse?
Thanks!
Dan
Subject: Your NotesStream is Empty
The NotesStream.WriteText will write whatever is in the stream. Your stream is empty. You need to do a NotesStream.ReadText or Read to load the stream, and then pass it to a DOMParser.
