NotesDOMParser and External Entities with relative paths. (Second post)
Hello All,
This is my second post, I am running into a dead end. Any help is greatly appreciated. Here is my issue…
I am trying to transform an XML file to DXL and trying to transform non domino data into lotus notes document using a custom XSLT.
The XML file has external reference to other xml files,
Like so…
I am using LotusScript NotesDomParser at the moment to parse and further transform it. It works great when I give the absolute path. However my most inputs XML file do not use absolute paths at all.
When the entity is referenced like below, I am getting errors.
I am not sure how to proceed further on it. I kind of understand, that the base path is relative to the lotus\notes executable directory poosibly, however how can I make it work for my situation, where the entities will have paths relative to the main xml files. I would appreciate if anyone get direct me to a solution.
Here is snippet of my code (its quite simple)
Set xmlin=session.CreateStream
If Not xmlin.Open(xmlFileLoc & xmlfilename) Then
Messagebox "Cannot open " & xmlfilename, “Error”
Exit Sub
Set transformer=session.CreateXSLTransformer()
Set domparser = session.CreateDOMParser(xmlin, transformer)
Set importer = session.CreateDXLImporter()
transformer.InputValidationOption =0
transformer.ExitOnFirstFatalError = False
importer.InputValidationOption =1
importer.ExitOnFirstFatalError = False
domparser.ExpandEntityReferences = True
On Event PostDOMParse From domparser Call PostDOMParse
Call domparser.process
