NotesDocumentCollection Help
Hello folks,
I’m hoping lotus script guru can point me in the right direction with this issue…
I’m trying to write a script that responds to the Querysave event. The script searches the current database when the Querysave event fires and checks to see if the invoice number contained in the current document exists in a document somewhere in the database. If the invoice number exists the document can’t be saved so we aren’t getting duplicate requests on the same invoice number.
Below is a copy of my script… The issue I am having is that I’d like for the script to exclude the document currently open in the NotesUIWorkspace from the NotesDocumentCollection.
The reason for this is approvers need to go into the document after it is initially saved and edit / add comments and resave the document. The script currently finds a match after the initial save and pops up my error message that a duplicate invoice number exists.
Any help with this issue would be greatly appreciated. Also if you have a better method of accomplishing my goal please let me know. I’m certianly open to suggestions. The only thing I would like to avoid using is the “isnewdoc” property in this fashion:
Excerpt (I do not want to use this method):
If source.IsNewDoc Then
	searchFormula$ = {Form = "taxCertRequest" & invoice_number="} & _
	Trim(Source.FieldGetText("invoice_number")) & {" }
	Set collection = db.Search(searchFormula$,Nothing,0)
	Set doc = collection.GetFirstDocument()
'Action if there is a matching document
	If (doc Is Nothing) Then
		Continue = True
	Else
		Continue = False
		Messagebox "A tax credit request for invoice number [ " & _
		Trim(Source.FieldGetText("invoice_number")) & _
		" ] already exists in the database! This request will NOT be saved." , 0 + 16,"Field Contains Incorrect Value"
The full script script I’m working with:
Sub Querysave(Source As Notesuidocument, Continue As Variant)
'Access to the current document.
Set Source = workspace.CurrentDocument
'Query the database for invoice number.
Dim db As NotesDatabase
Dim collection As NotesDocumentCollection
Dim doc As NotesDocument
	Continue = True
Else
	Continue = False
Subject: NotesDocumentCollection Help
I think that all you really need to do is to loop through the doc collection, and look for a doc with a different UNID than the one you are currently editing…
Once you have established your collection then…
Continue = True
if collection.Count < 1 then Exit Sub
Do While Not( doc Is Nothing )
If doc.UniversalID <> Source.Document.UniversalID Then
Continue = False
Exit Do
Set doc = collection.GetNextDocument( doc )
Loop
If your database already has a view that is sorted by Invoice No., then I would probably use that view to establish your document collection as well (should be faster than using db.Search). In that case, you would use GetAllDocumentsByKey instead.
Hope that helps!
T.
Subject: RE: NotesDocumentCollection Help
Thank-you for your help Terry that is exactly what I needed to get me going in the right direction! I’ve done a fair bit of testing and it appears to be working like I need it to be.
Here is what I ended up with:
Dim view As NotesView
Dim dc As NotesDocumentCollection
Dim InvoiceNo As String
InvoiceNo = Source.FieldGetText("invoice_number")
Set view = db.GetView("AllDocuments")
Set dc = view.GetAllDocumentsByKey(Trim(InvoiceNo), True)
Set doc = dc.GetFirstDocument()
If dc Is Nothing Then
	'Exit sub if the document collection does not contain any results
	Continue = True
	Exit Sub
While Not(doc Is Nothing)
	'Ensure the document is not new otherwise the UniversalID on the Source document is not set.
	If Not Source.IsNewDoc And (Source.Document.UniversalID = doc.UniversalID) Then
		Continue = True
	Else
		Continue = False
	Set doc = dc.GetNextDocument(doc)
Wend
