hcl-bot
1
I have some problem for my application that use the function notesdocument.send(true)
In Windows system this work and the result is a HTML mail with my formattation code.
In OSX Lotus Notes client the mail isn’t in HTML but only text when using this function.
Is this a Bug?
hcl-bot
2
Subject: Ops…is the server problem…
I have tested my code from Windows…and I have the same result…It’s a server Problem that don’t convert the document in html -email…
The problem is the configuration setting in
MIME → Convertion Options → Outbound the correct value is from Notes to Plain Text and HTML.
Now all work correctly
