Hi! I know I´m facing an “old problem”.Is there a way we can use notesUIDocument class in an schedule agent?.
I need to open a document from a view (edit document), and print it as PDF, obviously it works fine if it is started from Action Menu, but I need to automate the process.
Subject: Notes UI Clasess and Scheduled Agents - Julie K. Help Please!
I would think some third-party tool could do this quite easily, though I’ve not had to do it so no such tools spring to mind. It has to be a common and easily solvable problem.- Hope this helps…
Subject: RE: Notes UI Clasess and Scheduled Agents - Julie K. Help Please!
Will work. We have a third party product handling pdf creation this way. However this method is a bloody pain and not that stable at all. Could be because the programming of the third party tool, could be because of the notes system.
