Subject: Here is my ms word export code… I use tables for formatting
hope this helps:
Declarations:
Const wdItem = 16
Const wdCell = 12
Const wdFormatDocument = 0
Const wdGoToTable = 2
Const wdInsertCellsEntireRow = 2
Const wdInsertCellsShiftDown =1
Const wdLine =5
Const wdCharacter = 1
Const wdPageBreak = 7
Const wdAutoFitContent=1
Const wdExtend=5
Const END_OF_STORY = 6
Dim session As notessession
Dim db As NotesDatabase
Intitalize:
Sub Initialize
On Error Goto errtrap
Dim db As notesdatabase
Dim vc As notesviewentrycollection
Dim entry As notesviewentry
Dim x As Integer
Dim uiview As NotesUIView
Dim doc As NotesDocument
Dim item As NotesItem
Dim contents As String
Dim holdseq1,holdseq,p As Integer
’ Set uiview = ws.CurrentView
’ viewalias$=uiview.ViewAlias
’ Set view=db.GetView(viewalias$)
Set view=db.GetView("TOC")
Set vc = view.AllEntries
If vc.Count=0 Then
Msgbox "no documents!!"
Exit Sub
Dim numtxt As String
’ numtxt$ = Cstr(Inputbox$(“Enter Chapter Number”))
numtxt$=db.Title
’ If Trim(numtxt$)=“” Then
’ Msgbox “Operation cancelled!”
’ Exit Sub
’ End If
Set wordapp = CreateObject("Word.Application") 'Create Word object
’ wordapp.Visible = False
wordapp.Visible = True
Call wordapp.documents.add
Set worddoc = wordapp.activedocument 'Get a handle for the active document
Set entry=vc.GetFirstEntry
x=1
p=1
While Not entry Is Nothing
Set doc = entry.Document
holdseq=doc.SectionNum(0)
’ numtxt$="Sequence: " & Cstr(holdseq)
Call createTable(session,db,wordapp,worddoc,vc,entry,doc,x,numtxt,p)
x=x+1
Set entry= vc.GetNextEntry(entry)
If Not entry Is Nothing Then
Set doc2 = entry.Document
holdseq1=doc2.Sequence(0)
If holdseq = holdseq1 Then
p=p+1
Else
p=1
Wend
Exit Sub
errtrap:
ERRtxt= "Error: " & " : " & Str(Err) & ": " & Error$
Print ERRtxt
Msgbox ERRtxt
Exit Sub
Sub createTable(session As NotesSession,db As NotesDatabase,wordapp As Variant,worddoc As Variant,vc As notesviewentrycollection,entry As NotesViewEntry,doc As NotesDocument,x As Integer,numtxt As String,p As Integer )
’ On Error Resume Next
On Error Goto TABLEERROR
With Wordapp
Print "Processing " & Cstr(x) & " of " & Cstr(vc.Count) & " : " & Trim(doc.Title(0))
'Create the Issue Log table with 8 columns and how ever many rows we decided we needed earlier
’ .ActiveDocument.Tables.Add wordapp.Selection.Range, 4,8
.ActiveDocument.Tables.Add wordapp.Selection.Range, 4,1
’ .ActiveDocument.Tables(x).Add wordapp.Selection.Range, 4,4
'Reduce horizontal padding in cells; don’t allow rows to break across pages; set all cells to font size 9
.Selection.Tables(1).Select
.Selection.Borders.Enable =True
' .Selection.Borders.Enable =False
' .Selection.Rows.AllowBreakAcrossPages = False
.Selection.Rows.AllowBreakAcrossPages = True
.Selection.ParagraphFormat.SpaceBefore = 5
.Selection.ParagraphFormat.spaceBeforeAuto =True
.Selection.ParagraphFormat.SpaceAfter = 5
.Selection.ParagraphFormat.SpaceAfterAuto = True
.Selection.ParagraphFormat.LineSpacingRule = wdLineSpaceSingle
.Selection.ParagraphFormat.CharacterUnitFirstLineIndent = 0
.Selection.ParagraphFormat.LineUnitBefore =0
.Selection.ParagraphFormat.LineUnitAfter = 1
'Repeat table headings on each new page; set table headings font to bold
.Selection.Tables(1).Rows(1).HeadingFormat = True
.Selection.Font.Bold = True
.Selection.Font.Size = 12
'ROW 1 db title
' .Selection.TypeText Trim("Chapter " & numtxt)
.Selection.TypeText Trim(numtxt)
.Selection.Tables(1).Rows(1).Select
.Selection.MoveDown wdLine
'row 2
.Selection.TypeText Trim(Cstr(doc.SectionNum_1(0)) & ". " & doc.Section(0))
.Selection.Font.Size = 9
'ROW 3
' .Selection.TypeText "Title"
' .Selection.TypeText Chr(10) & doc.Topic(0)
.Selection.TypeText Trim(Cstr(doc.SectionNum(0)) & ". " & doc.Topic(0) )
’ .Selection.MoveDown wdLine
.Selection.Font.Bold = False
.Selection.ParagraphFormat.LineUnitBefore = 0
.Selection.ParagraphFormat.LineUnitAfter = 0
'GetRichTextContent(doc As NotesDocument, db As NotesDatabase, session As NotesSession)
Dim RText As NotesRichTextItem
Dim RTNav As NotesRichTextNavigator
Dim RTRange As NotesRichTextRange
Dim count As Integer
Dim TextString As String
If doc.HasItem("Body") Then
Set RText = doc.GetFirstItem("Body")
If (RText.Type = RICHTEXT) Then
Set RTNav = RText.CreateNavigator
Set RTRange = RText.CreateRange
If RTNav.FindFirstElement(RTELEM_TYPE_TEXTPARAGRAPH) Then
count% = 0
Do
count% = count% + 1
Call RTRange.SetBegin(RTNav)
TextString$ = TextString$ + RTRange.TextParagraph
Loop While RTNav.FindNextElement(RTELEM_TYPE_TEXTPARAGRAPH)
wordapp.Selection.TypeText Chr(10) & Trim(TextString$)
%REM
’ .Selection.Cells.Merge
’ ROW 4
Set item = doc.GetFirstItem( "Body" )
contents = Fulltrim(item.Text)
cValue=Replace(contents,";",Chr(13))
%END REM
' cValue=TextString$
.Selection.TypeText Chr(10) & Trim(cValue)
' .Selection.Tables(1).AutoFitBehavior (wdAutoFitContent)
.Selection.EndKey END_OF_STORY
.Selection.TypeParagraph
' .Selection.Insertbreak wdpagebreak
End With
Exit Sub
TABLEERROR:
'Msgbox "ERROR WITH #" & Cstr(x) & " : "& DOC.DESCRIPTION(0)
Print "ERROR WITH #" & Cstr(x) & " : "& DOC.Topic(0)
ERRtxt= "Error: " & Str(Err) & ": " & Error$
Print ERRtxt
Msgbox ERRtxt
Resume Next
