When the user tries to run Notes client 8.5, they are challenged for a password and the little progress bar goes all the way accross to 100%.
The splash screen goes away but the UI does not come up. This has been happening for a few days now.
I have done a install/repair of notes client
Subject: Re:
Does the app close after that window? If so, see if that user has Unsanity’s Application Enhancer installed. Notes wouldn’t open for me unless I had APE completely disabled.
Subject: This is an XP machine
It looks like unsanity is a for MAC’s. Either way, he does not have that installed.
Thanks though.
Subject: Woops
Sorry about that. I keep on forgetting this is a Notes 8.5 forum, platform-independent.
Subject: maybe this helps
hi,
i’m having the same problem. try this http://www.weightlessdog.com/shell.nsf/d6plinks/TTUE-7GBQ8H
greets
hans
