Notes Rich Text Range: Problem with TextRun
I hope someone can help - I’m going mad! Here is wot I am trying to achieve - it’s simple but I just cannot get it to work: I have a RT field on a document containing string text only. Wherever there is a string of colour red, I am simply, at the moment, trying to change it’s colour to, say, blue.
Below is some code whereby I first create a RT Navigator to the rt field on the document. I then create 2 ranges: One which I set at paragraph level and the other at text run level within the paragraph. The darn thing just does not work! Is it my coding is it a bug with navigators/ranges??
Anyhelp greatly appreciated.
Sub Click(Source As Button)
Dim uiws As New notesuiworkspace
Dim db As NotesDatabase
Dim view As notesview
Dim rtitem1 As NotesRichTextItem
Dim doc As NotesDocument
Dim rtnav1 As NotesRichTextNavigator
Dim style1 As NotesRichTextStyle
Dim rtnavPara As NotesRichTextNavigator
Dim rtrangePara As NotesRichTextRange
Dim rtrangeRun As NotesRichTextRange
Dim paraCount As Integer
Dim runCount As Integer
Set view = db.GetView("testdocs")
Set rtitem1 = doc.GetFirstItem("body")
Set rtnav1 = rtitem1.CreateNavigator
If rtnav1.FindFirstElement(RTELEM_TYPE_TEXTPARAGRAPH) Then
	Set rtrangePara = rtitem1.CreateRange
	Set rtrangeRun = rtitem1.CreateRange
	Do
		paraCount = paraCount + 1
		runCount = 0
		Call rtrangePara.SetBegin(rtnav1)
		Call rtrangePara.SetEnd(rtnav1)
		Set rtnavPara = rtrangePara.Navigator
		Call rtnavPara.FindFirstElement(RTELEM_TYPE_TEXTRUN)
		Do
			runCount = runCount + 1
			Call rtrangeRun.SetBegin(rtnavPara)
			Call rtrangeRun.SetEnd(rtnavPara)
			Set style1 = rtrangeRun.Style
			If style1.NotesColor = COLOR_RED Then
				oldstring = rtrangerun.TextParagraph
				style1.NotesColor = COLOR_BLUE
				Call rtrangerun.SetStyle(style1)
				Call rtrangerun.FindandReplace(oldstring,rtrangerun.TextParagraph,1+2+4)
				Call doc.Save(True, False)
				'reset nav positions:
'go back to first para in rt field.
'now find para that contained red text and recreate a navigator pointing to it - this bit is ok.
					If rtnav1.FindnthElement(RTELEM_TYPE_TEXTPARAGRAPH, paracount) Then
				'now find the next text run AFTER the red text run
				If rtnavpara.FindFirstElement(RTELEM_TYPE_TEXTRUN) Then
					If rtnavPara.FindnthElement(RTELEM_TYPE_TEXTRUN,runcount)  Then
		Loop While rtnavPara.FindNextElement(RTELEM_TYPE_TEXTRUN)
	Loop While rtnav1.FindNextElement(RTELEM_TYPE_TEXTPARAGRAPH)
Subject: Notes Rich Text Range: Problem with TextRun
Just started fiddling with this… I created newstyle.NotesColor = NewColor,
Using your style1
Set Style1 = rtrange.Style
			If style1.Notescolor = Color_black Then
				Call rtrange.SetStyle(newStyle)
				changed = True
if changed, save the form, close and reopen uidoc.
Still working on highlighting a word…:slight_smile:
Subject: RE: Notes Rich Text Range: Problem with TextRun
Thanks Marilyn. My code does a lookup to a view to find the doc containing the RT field and then tries to process the text so does not use the uidoc.
The code will eventually be run as part of a querysave event on a form presented to the user in a browser.
Thanks for your help - anymore wouldbe great!..:o)
