This is the thing that’s happen:
Starting Windows
Starting Notes
Notes
Notes says: You cannot use the administration program while the domino server is running…
Shutdown Notes
Run Killnotes.exe ( shuts 2 notes processes)
Starting Notes
It WORKS!!!
Now:
Shutdown Notes
Starting Notes
Shutdown Notes
Starting Notes
It WORKS!!!
What is going wrong???
Subject: Notes Quitting problem
Oh yah!!
Even after a reboot he still thinks the domino server is running!!!
Subject: RE: Notes Quitting problem
Check the read/write rights the user has on the folder/drive where the notes.ini is located. I’ve seen this behavious if the client is not able to write to the notes.ini
Sahin & Bart,
I’d check the startup folder and the registry… nothing found strange. I’d also checked the read/write rights… and that’s in order to! So that can’t be it :S
Remy
HI
check services …if any notes program is running on startup
HTH
Sahin
The “You cannot use the Administration program while the” frequently occurs because you’re executing nlnotes.exe instead of notes.exe.Nlnotes.exe functions as a workstation client just like notes.exe but using nlnotes for desktop functions such as opening NSF files and printing multiple selected documents wreaks havoc and is responsible for hairloss and probably a few divorces.
Exit Notes and execute notes.exe and retry your tasks and you’ll likely avoid this insidious error message.
…whether you EVER experience a hassle free Notes experience is less likely than finding a relaxed hamster in W. Hollywood.
Oh ya!
Even after a reboot he thinks the Domino server is running!
