After upgrading to Lotus Notes 8.0.1 I have very strange problem with Notes minder.After starting, Minder is in tray and also in Window (???).
In previous version he was only on tray.
If I close this Window, Notes minder also will be closed.
Any idea, why?
Subject: We reported this issue to IBM
We immediately noticed a similar issue with Notes Minder after upgrading to 8.0.1. This issue is that the Notes Minder icon appears in both the icon tray and the program bar.
IBM had already opened an SPR by the time I reported it: SPR NCTN7C6SMS
Assuming that the problem description matches I would recommend contact IBM support and reporting another instance.
Subject: IBM support !?
Thanx, William. IBM Support recommended us opening of PMR in IBM. :(.
Subject: Call support again and tell them yes, you do want to open the PMR…
…and would they please do so?
