Notes Item Not Found - Different Problem?
I have read several examples on this forum to do with Notes Item Not Found messages but nothing seems quite like mine, unless I have missed a particular posting.
In my application I am creating a new form using @Compose which inherits specific fields from the currently open document using the form property Formulas Inherit Values for Selected Documents. So on this new form I have fields with the same name as those on the previous form that I wan’t to inherit, and they are computed with the computed value the same as the field name. This new document does not need any edit facility as it is used to reformat the data in the currenly opened document so its more suitable for printing / viewing.
This works fine for all types of fields except when a rich text fields contains an attachment or a picture. Normal rich text properties like bold, underline, font changes, tables, doc links etc come across fine, but attachments and pictures don’t. When I create the inherited document I get an error message Notes Item Not Found for each attachment or picture, and for each one a white box with a black outline with a down arrow in the top left corner.
I understand from what I have read here that attachments won’t come across correctly to an inherited document as the $FILE information doesn’t come across as well. This is fine as the inherited document is only for view / printing purposes. But I thought at least I would get the bitmap icon of the attachment, and then only an error message if someone tries to open it. And I would have thought the picture would come across OK as well, unless this is the same reason as the attachment $ FILE issue.
Most of the posts I have read here seem to indicate that attachments don’t come across but the bitmap representation does, and only when the user tries to open the attachment does it generate an error.
I am using Windows XP, with Notes version 6.0.2 CF1. Other users are experiencing the problem also.
Subject: Notes Item Not Found - Different Problem?
If you don’t need to edit or save this document, but are just wanting to temporarily open a “printer-friendly” version of an existing document, why bother composing a new document at all? Create a second form that contains all of the fields you want from the first form, then use @Command( [ViewSwitchForm] ; formName ) to display the document in the print-friendly form?
Subject: RE: Notes Item Not Found - Different Problem?
Thanks Esther!
That works great, and any attachments, pictures etc display fine. You are quite right, I don’t need to create a new document as its only for printing. Just changing the form used to display the document is logical really, but I didn’t think of it. I haven’t come across this SwitchForm @Command before.
Once again thanks, its been a lifesaver!
