Notes instant messaging - Formula or script help
All, Do someone knows where I can find information on how to play with Notes Instant messaging with Formula or script ?
 In domino help, the is only 4 command avail...
 I need to trigger something as soon as I receive a new instant message.... But can't find any code
 Thanks in advance !
Subject: Notes instant messaging - Formula or script help
Look here
JYR
Subject: RE: Notes instant messaging - Formula or script help
Merci Jean-Yves, but I can’t find anything for what I need on this site
Have you saw something interesting ?
Merci a l’avance !
Sylvain
You can search for the word “Awareness”
You have examples available for download, you can look in the resource section of those links you will have other links
JYR
STAgent created by my company can send Sametime messages, announcements, check user’s online status using LotusScript agents, Java agents and command line.
You can also use it STAgent as a java servlet, which makes it possible to send Sametime messages from Javascript and HTML.
There is a 30-days evaluation version.
Link: LotusScript API for Lotus Instant Messaging integration
You might try posting or searching the SameTime forum…
http://www-10.lotus.com/ldd/stforum.nsf/CategoryAllThreadedweb/
