Notes Error: Entry Not Found in Index (viewname)
I receive the error message - Notes Error: Entry Not Found in Index (viewname) when I attempt to run the following agent:
Sub Initialize
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim rtffield As NotesRichTextItem
Dim ebo As NotesEmbeddedObject
Dim view As NotesView
Set view = db.GetView (“Pdf Attachments”)
While Not(doc Is Nothing)
afp = doc.FaxOnDemand
afp1 = Cstr(afp(0))
Set rtffield = doc.CreateRichTextItem(“Body”)
Set ebo = rtffield.EmbedObject(EMBED_ATTACHMENT,“”,"c:\RCRA" + afp1 + “.pdf”)
Call doc.save(True,True)
Set doc = view.GetNextDocument(doc)
Wend
I have already tried recreating the index, view, and agent with no success. The agent has worked in the past with no problems. Any help would be greatly appreciated. Thanks.
Chris
Subject: Notes Error: Entry Not Found in Index (viewname)
When you save the document with Call doc.Save(True,True) you will force the viewindex to be rebuilt. This will cause the GetNextDocument() to throw out the error “Entry not found in index”, since the current object is out of scope for the viewindex that is held in the view-object.
You can try a couple of things to overcome this problem:
Instead of using GetNextDocument, move the objectpointer to the first document in the view with “GetFirstDocument()” method. If You use this approach - I suggest that You have a viewformula that will not include documents that You have embedded pdf’s in them. Or You will be ending up in a never ending loop.
The next thing You could try is to set the viewproperty “AutoUpdate” to ‘False’ before the loop starts and then set it back to ‘True’, when the loop has finished. This I haven’t tried, but it seems that this should be applicable according to the help documentation.
hth
Thanks guys! That did the trick.
Subject: This may or may not work, but try…
Set view = db.GetView (“Pdf Attachments”)Set doc = view.GetFirstDocument
view.AutoUpdate = False
afp1 = Cstr(afp(0))
Wend
