I set up two Domino 6.5.4 Servers to be in a cluster. I adjusted the ACL’s so that both servers have manager access to each. From the Domino Admin console, when I try to create a replica of any database on the additional server, I get
admin process - Destination does not support RE/FWD status.
I’ve tried to research the problem but with no luck. Any help with this would be greatly appreciated.
Subject: Notes Cluster Problem - admin p- RE/FWD Error
try this
disable “Mark parent note on reply or forward” on the database(this option can be found in database properties box,fourth tab from left) .Then try to create a new replica on the other clustermate via adminp process(i.e create replica).
