Notes 9, Domino 11 and SAML in the same boat!
Hi everyone,
We moved to Windows Server 2019 for your AD FS (not from my will) and for some reasons we want using SSO for Notes on Citrix.
For some reason again, we still using Notes 9.0.1FP9 (we can't go futher, no more support). But we have Server support so we can use Domino 11.0.x. And I think we was lucky because ADFS 4.0 is supported since Domino 10.0.x.
So, I tested SAML and NFL in my sandbox with Domino 11 and ... Notes 11 (for tests purpose). And that works fine.
Now, I switched to Notes 9.0.1FP9IF2 ... and I got a failure.
This message in Notes console log (Debug_console=1) :
PH3_SAML_Interceptor> Failed to retrieve IdP information
This popup in Notes client :
Network error: the message content was unexpexted or the message has been corrupted
And I saw the XML message in Domino console (Debug_SAML=31) so I guess it's well formed and the client got it.
Is such environment (Notes 9, Domino 11, ADFS 4) supported ? The documentation talks about compatbility for ADFS 4 in Domino 10.0 and above, but never talks about Notes client, is it imply ?
For Citrix and SAML support, you would be best served by Notes 11, as you have already found out in testing.
HCL has several programs where re-licensing is available at very reasonable prices. I strongly suggest to investigate and get an actual quote from HCL what the cost for reinstating the maintenance for the client licences. You might be pleasantly surprised!
Re-licensing is not an option, sadly.
But are Notes 9 with Domino 11 and SAML/NFL compatibles ?
If not then I'll stop my investigations.
Notes 9 and NFL (Notes Federated Login) via SAML is possible, see https://help.hcl-software.com/domino/9.0.1/admin/admin/secu_using_a_security_settings_policy_to_assign_federated_login_to_clients_t.html.
But: requires ADFS 2.0 or ADFS 3.0. So if your ADFS 4.0 can supply Domino with ADFS 3.0 or ADFS 2.0 protocol messages, you should be OK, because ADFS 4.0 support was introduced in Domino 10. I do not know if Notes 9 clients will work if Domino 11 is on the server.
See: https://support.hcl-software.com/sys_attachment.do?sys_id=fbf36b8d1b1b378083cb86e9cd4bcb93&usg=AOvVaw1OCzZkLxNyyEtzTjMwwWjj
for a comprehensive HCL support document on Domino and SAML
Notes 11 adds NSL (Notes Shared Login) on Citrix. NFL is already supported on Citrix on Notes 9.
Note: if you are running Notes on Citrix, you MUST view the webinars by Panagenda on the subject. Excellent stuff!
