Not your typical Rule Problem
I have a user who has a rule that uses the send copy to action to forward all messages received to his blackberry. The rule works fine except that at some point in the night it stops working. When that happens I can see the ol’ “contains no recipients” error in the log every time the rule tries to run. I can easily fix this by going into the rule and re-adding the address in the Action but I have to do this everyday and it’s getting a little annoying. I’ve tried recreating the rule, but that doesn’t seem to stop it from “forgetting” who it’s suppose to send its messages to. I have other employees on this server that use the same type of rule without a problem. Any ideas?
Subject: Not your typical Rule Problem-Solution
I was able to fix this problem, by just running a simple Fixup and Updall.
