Not categorized help please
Morning all,
Im new to lotus notes and I am experiencing a (not categorized) problem with my views.
I do apologise if this sounds a silly question, but how do i resolve this?
I have a set of forms which consists of broken down tasks. I have the following fields on each form…‘TskOne’ field (computed for display field that will display the task question), Comments field (which is text and editable allowing the user to input comments if required) and a Completed? field that is a dialogue list allowing the user to say whether the tests carried out are complete or not.
Ideally on my views I would like it to display something similar to the below but how do i achieve this and get rid of the ‘not categorized’ view.
Test#: | Task Question: | Comments? | Completed?
Tsk1
      | Is H/W connected?|         n/a          |    Yes
Tsk2
      |  Is S/W installed?  |       Norton       |    Yes
Tsk3
        Network Cable          Not connected     No
etc
*Note: The information will be displayed under the headings…
Can someone please advise me.
Many Thanks
Subject: Not categorized help please
A computed for display field does not show up in a view. It is never saved on the form. Make that field computed.
