Hi All,
I am listed as a Manager to the database and I have Author’s Field a multivalue Field in the form
I also have a user who has Author access in the ACL and he is also listed in the Author Field of the same form as it is a multivalue filed
When I open the Form , I am in the Edit mode and the fields are editable.
When the user opens the form , he is in the read mode eventhough he has Author access and he is also listed in the Author’s Field .
The values of both the users in the Author’s Field is in the Canonicalize format “CN=Test1/O=XYZ”
“CN=Test2/O = XYZ”
Also when I look in the document properties and the Filed value of Authors Field I see Field Properties Flag SUMMARY READ/WRITE-ACCESS NAMES
Please help
Thanks in advance
ac ac
Subject: Not able to edit the Document —Please help
but the question is who created those document a person who is having author access can edit only those document which is created by him his name must present in author field
Subject: RE: Not able to edit the Document —Please help
Priyank, that is not true- the values in the Author field grant Author access- @username as a formula in that field allows that user to edit it- but one can put other values in the field- I put groups in there to allow group authorship, and progratically change the author field to “[Admin]” to disallow author’s from editing a document after a certain point in time. I do think there are two possible issues,a) it is not a multivalue field, as previously questioned
b) the name is not in the right format
ac ac,
I would confirm that the field is multi-value. Even if it’s not, you’ll get EDITOR access because of your ACL access.
Second, I would confirm that the user’s name is in there exactly right. I recently ran into cases where some name changes had not been pushed through to applications and so people didn’t get the right access to documents because their OU had changed.
regards,
raphael
