Not able to edit document using Authors field
I have the manager access right for a database. Then i create a document using Form1. The form has a computed Authors field with formula @UserName.
But I have a user with Author access right can not edit the document. I just wonder the formula in the Author field is not correct?
Can someone tell me ? I really have no idea. Thanks
Subject: Not able to edit document using Authors field
Hi
R u working on u local copy or server copy…!
Subject: The two most common problems
The two most common problems in this scenario are:
  1. You didn’t use canonicalized names, or,
  2. You didn’t set the multiple values flag on the field.
Now, your problem might be something different, but those seem to account for the lion’s share of such problems.
Subject: RE: The two most common problems
I work on server copy.
I confirmed that i have checked the multivalue box and not using the CN name
Ofcourse that user will NOT be able to edit a document created by you since the Authors field contains your name.
He will only be able to edit if :
  1. His name is listed in the Authors field
  2. Has Editor access or above in the ACL.
cheers !!
Ashish
Subject: RE: Not able to edit document using Authors field
Just to clarify, I presume Ashish meant if one OR the other condition was true, not if both were true.
Yes i meant OR and hence any of the one conditions has to be true.Thanks Ben.
