i created a folder , but i am not able to delete that one or remove. its showing a message " The action may not be done".please help me to solve this problem
veena mariya john
veena mariya john
Subject: Not able to delete folder PLEASE HELP
Are you a Notes Administrator?
Subject: RE: Not able to delete folder PLEASE HELP
hi paul,
this is not a chatting site, everybody is trying to get there problem to be solve. if you know the solution please help. other wise leave it
is ther any other person to help me???
veena mariya john
From your error message
http://www.google.ca/search?hl=fr&q="The+action+may+not+be+done"&btnG=Recherche+Google&meta=
JYR
For faster answers, be C R I S P Y
I’m quite aware of what/who this site is for. Your question/problem is quite remedial, especially for a Notes Administrator or Developer.
ok paul, i am only a user , trying to learn lotus notes administration. help me if its possible;)
veena
If you have at least designer privileges, you can create a simple formula language action on your action menu. Choose the @deletedoc (@command) and save it as an agent. Then delete everything out of the folder and selete the folder and run the action against it. It most cases it will delete it.
