Need your help again, I am trying to setup sso between websphere and our domino applications. We are currently running domino 6.5.1, I created the web sso configuration document, I then edited the site document to sso. But when I load the server I get the following error message
http server: no web sso configuration specified, using default (‘LtpaToken’)
then 2 more error messages that says error loading web sso configuration LtpaToken.
I have been trying to get this working for a week now, any help you could provide would be awesome, thanks LH
Subject: no web sso configuration - error help
Need a few more details on what you setup. Did you add the server to the SSO document? Did you generate Websphere token and then import it into the SSO doc?
Alex
Subject: RE: no web sso configuration - error help
Alex ,
Sorry I did not provide those the first time,
Here is an overview of how I tried to set it up
generated and exported the webspehre application ltpa token file.
went into the domino admin in server, web, then internet sites. , and created a Web SSO configuration document
imported the ltpa token that I created from webspehre, and it asked me for a password and filled in the ldap realm and ltpa version.
added the \ to my domain in the ltpa realm because it drops it on the import.
filled in my organization, domino server, and dns information.
saved and closed the document.
opened up the internet site document for the server, and under domino web engine, i changed session authentication to multi server sso and selected my sso token for web sso configuration.
saved and restarted the server.
I now get the following error message.
"HTTP Server: Error loading Web SSO Configuration ‘LtpaToken’ for Web Site ‘Intranet’
(Single Sign-On Configuration is invalid)"
i have tried a lot of different things, change the dns domain field, the organization field, and the participating server, but nothing seemed to work.
thanks for all the help.
Larry
Also check the Lotus Support Knowledge Base for document #1106654. (Lotus Domino Returns ‘Error Loading Web SSO Configuration ‘Ltpatoken’’ when using Internet Sites). It might help.
