Dear sir,
I have problem doing the nfixup on local because Notes Program is install on C:\ while the Data folder is on E:, when I run the fixup, it shows there is missing component.
The fixup need to be done because the database has exceed the limit and always perform consistency check.
Please advise on how can I run the fixup for the database that is located in E:\ and can also link up the component that are located in C:\
Thanks in advance
