I need to create a newsletter summary & have it run on a schedule. I have created a view that contains the documents (if any for that week) that should be listed on the summary. It works great when I run it manually, because I can select my target as all documents in the view. However, when I schedule it, the only options are all docs or all new/modified docs. When I do this, it still pulls the info on the correct ones, but I also “This document was not found in the view specified by the agent” over and over for each document in the db that was not in the view.
I know there has to be a way around this, but I cannot figure out what I need to do. I am not very good at LotusScript, and I have tried playing with the following. However, I am still not getting what I need.
Basically, what I need is an email with a listing containing information from 4-5 fields on documents that have been declined in the past 7 days. I have a declined field on my form that is a date field.
Here is one of my attempts at writing the script, but I am still not getting what I want.
Dim db As NotesDatabase
Dim collection As NotesDocumentCollection
Dim newsletter As NotesNewsletter
Dim doc As NotesDocument
Set mailDb = New NotesDatabase ("","")
Call mailDb.openmail
Set collection = db.UnprocessedDocuments
Set newsletter = New NotesNewsletter( collection )
If ( collection.Count > 0 ) Then
Set doc = newsletter.FormatMsgWithDoclinks( db )
doc.Form = "Memo"
doc.Subject = "Declined Claims for the week"
Call doc.Send( False, "Alison Wills" )
Any help would be greatly appreciated.
