Neeeeeeed help Reg View Column
We are trying to use the following code to show documents as links in a frame
URL1:=URL +“/alerts.nsf/All/”;“[<font color="#000000" size="1" face="Arial"><a HREF="”+URL1+@Text(@DocumentUniqueID)+“?OpenDocument">”+Title+“]”
The above formula works great in 4.6.7 and also preview in web at 6.0.3. But does not work in frames(in 6.0.3).
Tomorrow we are moving this DB test environment and we badly need the fix for it.
You can send the reply to Paruchuribros@hotmail.com
Your help will be appreciated.
