Need some help with richtext
I have the following code that I added to my iNotes60.nsf (mailfile) script library:
CoreEmailClasses>QuerySaveExtension
right after the line that says:
QuerySaveExtension = True
REM {Start - adding rich text to body of e-mail];
Call Source.Refresh
Dim doc As NotesDocument
Set doc = source.Document
Dim richStyle As NotesRichTextStyle
Dim richText As New NotesRichTextItem(doc, "Body")
Set richStyle = session.CreateRichTextStyle
Call richText.AppendText("The meeting is at ")
richStyle.Bold = True
Call richText.AppendStyle(richStyle)
Call richText.AppendText("3:00")
REM {End - adding rich text to body of e-mail];
for some reason it doesn’t append the rich text that I’m asking for (at all, not even as ‘unformatted’ text).
however, if I use the command:
Call Source.FieldAppendText(“Body”,“meeting is at 3:00PM”)
it works.
Any ideas on what I might be doing wrong or have is this a Lotus Notes limitation?
Subject: need some help with richtext
You have to save (or simulate saving with SaveOptions=“0”) and close and re-open to see rich text changes made through the backend.
Subject: RE: need some help with richtext
Hi Ben, thanks for the response.
Do you mean:
  • save document
  • retrieve document via backend
  • make richtext changes via backend
how do you ‘close and re-open’ a document that was never saved?
Andre’s post on this seems to be the most clear and comprehensive:
Tip: How to update rich text in a document that’s open and redisplay it without saving
