How will a do this the correct way? It works but a guess a could improve the code a lot.
If(doc.h_TaskEditors(0)="") Then
doc.dsp_TaskEditors = "-- Unassigned --"
If(doc.h_TaskEditors(0)="h_Both") Then
doc.dsp_TaskEditors = "Author and assignee only"
If(doc.h_TaskEditors(0)="h_Authors") Then
doc.dsp_TaskEditors = "Author only"
Subject: Use a ‘Select Case’ statement
Subject: RE: Use a ‘Select Case’ statement
Thats not help me, i’m looking at that but i-m not really shure how a will use it.
both of these should work:
Elseif(doc.h_TaskEditors(0)="h_Both") Then
Elseif(doc.h_TaskEditors(0)="h_Authors") Then
Dim taskedit As String
taskedit = doc.h_TaskEditors(0)
Select Case taskedit
Case ""
Case "h_Both"
Case "h_Authors"
End Select
Thanx, that help me a lot. I’m pretty new in LS so sometimes a completely have no idea what to do.
