Hello,
I am writing an App that has a table in it. The table has 8 rows that I want to hide until the user clicks on the Icon to add a new row. I have created a Graphic Image and the associated Hotspot. However I have no clue how to code this. I have tried setting a counter but the counter never updates.
I have never programmed this feature before and really have no clue where to look for help.
Any pointers would be greatly appreciated.
Thank you
Subject: Need some help please
Don,
For clarity purposes, you created an image of a table and you want to be able to add new rowws to this table if the user clicks on the hotspot? Question, have you looked into the NotesRichTextTable class? Here, you can add rows, remove rows, etc.
SPJ
Does the table always exist with the 8 rows & you want to make the next row visible when the user clicks the button?
If so, you need a counter field on the form which you increment through the ui doc.
You condition the hide when formula for all the cells in a table row based on the value of the counter, e.g for row 2 the hide when condition would be ‘counter < 2’.
When you increment the counter and refresh the uidoc, the new row will appear.
Subject: RE: Need some help please
That is exactlt what I want to do, display a row only when the user clicks the Icon. Thank you for the help I will try the counter option today.
