Need Javascript help...!
I have a link on a Page, which opens a new window which contains a view. The parent window also contains a view. However, when I click on my link, the frame in the parent over-writes the view with the word “Object”.
I’m not sure what i’m missing, but clearly I don’t want my view to be replaced with this message. I’m using IE6, and I don’t remember encountering this problem with IE5.5 which I was using before.
Any pointers would be appreciated.
Subject: Please post your javascript code.
Please post your javascript code that is called when you click on a link so we can help you.
Thanks.
Alex
Subject: RE: Please post your javascript code.
View Timesheets Full Screen
Thanks…
