I want to setup my HTTP Domino server and use SSL. We bought InstantSSL certificate but I’m not able to merge it into the Domino key ring.
Do somenone have the steps how to proceed?
I try to follow the Admin procedure hot to create the server Key ring but don’t know how to merge the InstantSSL certificate.
Also, do I need to create 1 Server key ring per server or can I use the same one for all my Domino server?
Thank you!
Alexandre
