Need help with remove doc
HiI want to remove all doc in aview there field orderOK is 0. I’m not use LS so often and is stuck here. Could anyone help me.
Sub Initialize
Dim session As New Notessession
Dim thisDb As NotesDatabase
Dim dc As NotesDocumentCollection
Dim v As NotesView
Dim doc As NotesDocument
Dim docStatus As NotesDocument
Dim profileDoc As Notesdocument
Dim Server As Variant
Dim DB As Variant
Dim collection As NotesDocumentCollection
Print "Delete document, Started at: " + Now
Set DB = session.CurrentDatabase
'Set Server = session.ServerName
'name$ = session.ServerName
Dim DBdoc As New NotesDatabase(Server(0), DB(0))
Set view = DB.GetView( "($All)" )
Set docStatus = session.DocumentContext
If(doc.orderOK(0)="0")	 Then
' Remove document
	While Not doc Is Nothing
		Set docNext = view.GetNextDocument(DBdoc)
		Call doc.remove(True)
		Set doc = docNext
	Wend
Print "Delete document, Finished at: " + Now
Kind regards
Fredrik
Subject: Need help with remove doc
make a NotesviewEntryCollection with the method GetallEntrysBykey. And dann Remove them all…
Dim db As NotesDatabase
Dim view As NotesView
Dim vc As NotesViewEntryCollection
Set view = db.GetView(“By Category”) 'your view
Set vc = view.GetAllEntriesByKey(“December”) 'your Fieldvalue
Call vc.RemoveAll(True) 'force to delete
Looping through all the documents and then checking for the condition would make a impact on the server performance if the number of docs to delete are more.
Do like this -
  1. Create a view with the selection formula set like -
Select form=“formname” & orderOK = “0”
  1. Write the following code -
Sub Initialize
Dim session as new notessession
Dim db as notesdatabase
Dim vw as notesview
Dim vc as notesviewentrycollection
set db= session.currentdatabase
set vw = db.getview(“viewname”)
set vc=vw.Allentries
vc.remove
msgbox “All docs removed”
End sub
Hope this helps.
–Phani
