Need help with parsing data from tsv file
I have a tsv file where the content is separated with space. Like below example. How I get the second (test1), and third data (test.nsf) from each line?
0000001 Test1 test.nsf 15 testing
0000002 Test3B test3b.nsf 23 testing3B
Thanks!!!
Subject: Split() ?
Try to read the row using Line Input, then use Split() to split the values into an arrray, using Chr$(9) (Tab) as delimiter:
Line Input #, row
valueArray = Split(row,Chr$(9))
Subject: It works!
Thanks!!!
Have a nice weekend!!!
