Need help with array
hi all…I need help with an array, I have an array IncPPt and it contains a list of doc ID, I need to add a new doc ID to it…
I tried this but I get a SubScript out of range.
NumInListe = Ubound(listUNIDPPT) + 1
Redim Preserve listUNIDQP( NumInListe -1 ) As String
listUNIDPPT( NumInListe ) =  dConfr.PPTUNID `I am getting the error here..
dQP.QPListeUNIDPPT = listUNIDPPT
Call dQP.Save( True, False )
thanks
A.
Subject: Need help with array…
why are you subtracting from NumInListe?
Increase your NumInListe as you are doing with
Dim NumInListe as integer
then
Redim Preserver ListUnIDOP(NumInListe) as String
ListUNIDOP(ubound) = listUNIDPPT
didn’t test it - but that SHOULD work
