Need help with an agent that will put all docs from view to body field
Hi, Need help with an AgentI need to have an agent, I guess that will take all of the documents from a view and put it in a body field on the web… how can I start this monster code…
thanks
A.
Subject: Need help with an agent that will put all docs from view to body field.
Well that is a problem, since you cannot get a document and add it to a richttext field.
Maybe there is another approach. What do you want to accomplish?
