Need help on DXL Importer urgent
I have used NotesDXLExporter to export all the design elements like forms,views,agents and so on.Then I am using NotesSAXParser to parse the dxl file as I need to modify them.Modified dxl file I am importing back using NotesDXLImporter.So Now the database has all the modified design elements.The problem here I am facing is modified form- field events are not working as expected.Like on change event is not working.If anyone has faced this type of problem or any help/suggestion on this matter is highly welcome.
Hema
