Hi All,I am creating a Web Based application.
I have a Functionality Search.
It has to search and display the search result in my form.
I Used $$SearchTemplate for Viewname form and Inserted $$ViewBody Field In the form to Embed by View to display the search result.
Its dispalying the Search result Properly…
My Problem is,
If I dont have any documents for that search result, then it should display “NO DOCUMENTS FOUND”…but instead its giving me a Blank Page…
Will the $$ViewBody will not give all the functionality of the embedded view??
What should be done to do this???
I tried one more thing , by giving the Hidden fld…
Having one computed value with default value as “documents found” and written The formuls !@isNull($$ViewBody) in the Hide when of the computed value…
But its not working…
It didnt consider the $$ViewBody as filed itself…
Need help to solve this problem…
Thanking you in Advance.
Cheers,
Sam Mathew
