Need help in javascript for the confirm and prompt
Hi…I need your help to write code in javascript…
I have 2 reqd…
i.e
  1. User needs to enter some value… so i use Prompt method in javascript… the box opens with title and text as
"Explorer user Prompt
Script Prompt:"…
I dont want that above 2 lines to be included…
I should be able to customize by prompt box…
which i can in Lotus Script… i wanted to do in javascript…
  1. I want 3 options in confirm box…
it has OK ,CANCEL and i want NO Also…
should i create a form to create customized confirm box…
thanks in advance
Subject: Need help in javascript for the confirm and prompt
ya of course,
u have to make one form and put your “liking” over there.
and click of any event
you can write "window.open(“And customized your window sized as u want”);;
Dev
Subject: RE: Need help in javascript for the confirm and prompt
thanks…I’ll create my customized form
You can use VBScript to have popup boxes with OK, Cacel, or Yes, No, Cancel.
