Need help in Attachments
Hi,I am creating notes document through a web form…My problem is with attachments.I am allowing users to attach attachments using fileupload control.
I want these attachment to go in a specific feild in Notes document.and it is not allowed to extract it in server and deattach it.
I have used code to copy all $File to notesdocument.So all attachments will come in bottom…
Then i have used code in Queryopen of notesdocument to extract it in client machine then again attach it to specific field using following code…
If doc.HasItem("$File") Then
			Dim rtItem As NotesRichTextItem
			Dim inputAttachment As NotesEmbeddedObject
			Dim filePath As String
			Dim moveToFieldName As String
			Dim vEval As Variant
			vEval = Evaluate("@AttachmentNames", doc)
			Forall v In vEval
				Set inputAttachment = doc.GetAttachment ( v )
				filePath = "c:\"+ v
				Call inputAttachment.ExtractFile(filePath)
				If doc.HasItem("SupportAttach") Then
					Set rtItem = doc.GetFirstItem ( "SupportAttach" )
				Else
					Set rtItem = New NotesRichTextItem ( doc, "SupportAttach")
				Set inputAttachment = rtItem.EmbedObject ( EMBED_ATTACHMENT, "", FilePath )
				Kill FilePath
			End Forall
My problem is i am not able to delete the attachment that is bottom…if i use doc.remove(“$File”),it will delete attachment in field also…
Can any one help?
Cheers
Merrin
Subject: Need help in Attachments
“I want these attachment to go in a specific feild in Notes document”
This is not possible on web :frowning:
Attachments will be always on the bottom of document , so, the only way to improved that, is to hidden attachment at the bottom and create a links to these attachments where you want , take a look at this Hiding attachments (without noscript tag!) - Article - CodeStore
(The exellent Jake Howlett’s site “codestore.net”)
Also here Control how attachments are removed - Article - CodeStore (with demo database available) you can control how attachments are removed.
and in “codestore.net” search for “attachment” there is other articles very useful…
and take a look in “sandbox” in this forum (at the right) I remember that there are managment tools for attachments for the web applications.
HTH
Thierry
Subject: RE: Need help in Attachments
No, you can move attachments in a WebQuery agent. After extracting the file to the filesystem, one needs to remove the attachment (NotesEmbeddedObject.Remove) and save the document, then re-create the attachment in the rich text field.
Thank you Stan.It worked…
Cheers
Merrin
