I am trying to investigate a huge amount of replication conflicts that have suddenly started appearing.
To this end, I am trying to design a folder in which I can display the ‘main’ and ‘conflict’ docs next to each other, with some further info alongside such as who updated, when, and on which server/replica. I know I can get this info from the doc properties, but I want it visible on the folder.
Any attempt to do so leads to frustration as the conflict doc folder entry will only ever display the ‘diamond’ and ‘[Replication or Save Conflict]’, even if you insert a special column just for responses.
Is there any way around this?
Thanks guys…
Suzie
