I want to create a Schedule agent on server…for Transaction LoggingActually we are storing our TXN file in the “domlog” directory as an archive based Transaction.
I want to archive my TXN files automatically with the help of agent (“Domdsmc archivelog” ---- this is the command which i want to use in this agent )
Directory path ==>> /notes/HUB007/domlog
But also i want to put a condition here it should be run when our directory crossed the size limit and that size limit should be 50 %
Subject: RE: Not sure I know what your question is
No, Just i want to create an agent for my domlog directory which is have the txn files and i want to archive the txn files automatically ( “Domdsmc archivel” this is the command which we use to archive txn files manually)
But this agent/command should be run when the my directory size crosed the limit of size (50%)
As per my understanding you may create a script
for “Domlog” directory. like once the directory reach the 50 % size this command will run automatically(domdsmc archivel) to the AIX platform
And for find out the size of the directory we use the following command
1.) Sh Diskspace domlog – this command we use on Domino console for checking the space for domlog directory
2.) Df -k|grep “server name” — on AIX platform
3.) Domdsmc archivel — this is the command we use for archive the txn file manually on the AIX platform
