Nedded help in opening view in Web
@URLOpen(dbPath + “/AllSortable?OpenView”)
I am trying to open one view in web…But it is not displaying all data.I knw i can set count to display that much documents in web.But i want to display all data according to the vie selection formula…
Can anyone help?
Cheers
Merrin.
Subject: RE: Nedded help in opening view in Web
So set count to some ridiculously high number. If there are fewer rows, it will display all of them.
If, use XSL and ReadViewEntries to generate a customized view experience.
Subject: Nedded help in opening view in Web
I used java applet view.Now all documents are showing
