NDB2Key.dll Issue's - Please Help
Hi All,
I am trying to enable DB2 on Domino 7.0.0 and have placed the NDB2KEY.dll in the program directory of domino but i get the message “dll is not a valid OS image error”. I have also tried regsvr32 but the dll does not get registered.
Is there anyone here who has done this before? Anyone from Lotus perhaps ?
Any ideas welcome.
Thanks in advance
Shamitha
Subject: RE: NDB2Key.dll Issue’s - Please Help
Copy the Correct Version of NDB2Key.dll in the Domino - Data Folder . The enable the transaction Log and Finish the DB2 access Setup and then make the DB2 access test .
Karthik
Do u think i should enable transaction logging before all this? cause once the dll is copied to the directory and I restart the server, it gives the error mentioning that the “dll is not a valid O/S image”. And this error reappears throughout the loading of the server. What do you mean by the correct version of the dll? The one i have is the dll from IBM website link.
Thanks in advance
Shamitha
Even I got the same Error when I do it for first time then I found that I placeed a different .dll file which belongs to different Windows OS . So please check the .dll for your windows and paste it .
Karthik
