Input needed.
I have several applications running in my job environement and we have started a process to upgrade to ND8. There has been some problems with the design (7.0.2 & 8) so far but,
On my laptop I have ND8 and client, designer and admin installed.
Home I have a local PC with 7.0.2 installations. They give me access to all files as before but when I try to open an application in the designer, Notes crash and start to dreate the log-file.
On the office today I changed some code (just a check in a if-then loop) from my lap-top. The client was ND8 based. Everything wnet OK. I should continue with some code-changes from my home office, but then it crashed.
It is not possible for me at the moment to connect up with the laptop to verify if this also happens then. Please give me some advices on this issue.
