How does one issue a compact on a local replica?
I tried using ncompact -c on a local replica to convert it to ODS48 but the db properties still says it’s ODS43.
Am I missing something?
Thanks!
Thanks!
Subject: NCompact -c to upgrade ODS
check this out… http://www.ibm.com/support/docview.wss?rs=899&uid=swg21267844
Subject: RE: NCompact -c to upgrade ODS
Thank you Rehan - that worked!
