NCompact -c to upgrade ODS
How does one issue a compact on a local replica?
I tried using ncompact -c on a local replica to convert it to ODS48 but the db properties still says it’s ODS43.
Am I missing something?
Thanks!
Subject: Create_R8_Databases=1
Hello Gerald,
to create/convert databases the notes.ini parameter “Create_R8_Databases=1” must be set.
As far as I know it just works for server databases, not for local databases.
HTH,
René
Subject: Solved
http://www-1.ibm.com/support/docview.wss?rs=899&uid=swg21267844
