Hi ,We have a application that run in cluster environment.
Now a document is process through the application and is router through ten approval cycles.
Problem.
The document that has went successfully through all the approval cycle is written . As a result of which it is back to step 3 .
This does not happen to all the document that are approved.
It happens only few times a month and cannot be predicted or Reproduce.
I feel that the replication is rewriting the document.
Any Thoughts are appreciated.
Sushant
