My "NSD is running.." issue has been solved!
Symptom :Recently whenever I open my email box, few minutes later will always receive “NSD is running…” message and Notes has been closed immediately…
Configuration : (R6 + XP )
Solution :
Check printer setting, is your default printer is a valid printer ? I mean mabye it has been removed out. My case is that the deault printer has been removed. Once I chaged deault printer to a valid one. No "NSD is running " happends !
I have also take a try with my another PC, which is NT OS + R6 Notes. The result is more worse, the whole system will crash and need to reboot. However if I change the default printer back, it’s ok again !
Just for all of you reference !
PS : actually I learn the solution from this forum, someone ever mentioned printer issue )
Subject: My “NSD is running…” issue has been solved !
Sir,
Thanks for providing the solution,I had also faced the same type of problem with windows XP+R6.In my case the default & valid printer was removed,after seeing the solution I configured the valid issue is resolved.Why this happen is this bug in windows XP or in R6,if somebody has some information kindly confirm through this forum
