Hi,I have 2 users in a domino server (user A and user B for instance).
User A can open user B calendar.
User B can open user A calendar.
(they can see each other’s calendar by using the option More->Open Person’s Calendar.
However, if I use “My calendars” new feature, I cannot see the other user’s calendar. In the Notes status bar (at the bottom) the error is some kind of
“You are not authorized to retrieve the other person data”
What am I doing bad??
Subject: Same Problem Here
I’m experiencing the same issue.
I have found that if I switch ID’s to an administration user, I can successfully add other users calendars to my own (so it does seem to be secuiry related as the error suggests).
Using a non admin user, despite setting maximum delgation access to target mailfiles results in the “not authorized to retrieve information from XXX”.
I am running Notes 8.5b1 against a Domino 8.5b1 server.
This is VERY frustrating as its a seriously cool new feature which we cannot show/test.
Nothing of any consequence appears in the server log or console.
Subject: Would you mind posting your logs
Subject: I dont mind but…
… I am pretty new on this and, as the client is Eclipse-based I would like to know which logs do I have to post here…
… sorry for the delay…
Thanks a lot!!
Subject: C:\Program Files\IBM\Lotus\notes\data\workspace\logs
Subject: Logs and screenshot
I removed all logs, then started Notes.Here are the fresh logs and the screenshot of
the error I was commenting…
Thank you very much.
